All Resources
Use case
Prevention of Unwanted Flare Spikes
Team TrendMiner
Industrial Analytics
Reading time:
Watch time:
10
min.
Updated:
Watch time:
August 21, 2025
Situation
For some industrial processes, side products or waste streams need to be released from the plant to prevent pressure buildup. These gases cannot be emitted in their original forms into the atmosphere because they can be toxic and harmful to the environment. Therefore, flares are installed to burn the gases to convert them into water and carbon dioxide. However, sometimes problems will occur in the process that will cause unwanted spikes in the flare.
Use Case: Prevention of Unwanted Flare Spikes
Problem
One of the plant’s flares showed deviations from normal behavior. At times, the flow toward the flare would spike, leading to an unwanted big flare. Ultimately this caused problems both with the neighborhood and with the local government due to flaring regulations. This issue needed to be investigated and solved. However, using traditional methods, the investigation would be extremely time consuming as it would involve browsing through various tags to try to find a potential issue. Moreover, the plant lacked tooling that had this functionality. The process experts needed a quick and efficient root cause analysis approach in which they could analyze the data to identify, describe, and address the problem.
Solution
Process experts used TrendMiner to solve this issue. It has the functionality to perform descriptive analytics to find out if this was the first spike or if it had happened in the past. Additionally, TrendMiner’s Recommendation Engine recommended all the potential tags that were related to the issue and helped the plant’s team find the potential correlations which they might not have found otherwise.
Approach
  • The process experts loaded the relevant tags to look at the data surrounding the flare spike. These results were then overlayed in preparation for using TrendMiner’s similarity search function.
  • The team used TrendMiner’s Similarity Search functionality to check for past events which helped in identifying the root cause of the problem.
  • Next, they used the Recommendation Engine to find potential correlated tags to expose the root cause. The problem was subsequently corrected, and measures were set in place to prevent it from happening again.
Results
  • Through easy data comparison, the process experts found instances of similar past behavior.
  • Using TrendMiner’s Recommendation Engine, the process experts found the root cause of the problem which was a malfunctioning valve. Maintence was informed to resolve the issue.
  • A monitor was set to warn the operation team of a potential issue which would give them time to take corective measure.
  • By resolving the unwanted flare spike, the environmental burden and the associated chemical waste were decreased.
Energy & natural resources
Anomaly Detection
Emission Tracking
Process Optimization
Process Engineer
Operator
Plant Manager
Shift Lead
Sustainability Lead
C-Suite
Share with a co-worker
Situation
Problem
Solution
Approach
Results
Access now
Situation
Problem
Solution
Approach
Results
Access now
Subscribe to our newsletter
